Fi&ll Forms (lastpass.cpp)
Help us translate LastPass into your favorite language
Postby J M » Mon May 11, 2009 2:58 pm
I see in lastpass.cpp item 12:
"Fi&ll Forms"
Is this correct? How should we translate the '&'?
Does it indicate a key shortcut? What if the letter does not match in the translation?
J M
Re: Fi&ll Forms (lastpass.cpp)
Postby sameer » Tue May 12, 2009 10:52 am
J M Wrote:How should we translate the '&'? Does it indicate a key shortcut? What if the letter does not match in the translation?
Hi J M,
Yes, it indicates a keyboard navigation shortcut.
You can retain them, and the application will do its best to accept the new shortcut key you provide.
eg: if you translate "Fi&ll Forms" into "Some &Text", then the application will do its best to map ALT-T in place of ALT-L
You could also omit the '&' character completely since keyboard navigation shortcuts are rarely, if ever, used.
eg: you could translate "Fi&ll Forms" into "Some Text"
Thanks,
LastPass
sameer
Site Admin
Return to Internationalization
