Identity master passwords?
Postby dragon2611 » Fri Mar 20, 2009 9:08 pm
I can think of a couple instances where it would be nice to be able to have a different master password for a secondary identity.
Particularly if you use multiple pc's so if your on a pc that perhaps you don't trust as much as your own pc you can have things stored that would be unlocked by a different password.
dragon2611
Re: Identity master passwords?
Postby Crusader » Sat Mar 21, 2009 10:07 am
Crusader
Postby dragon2611 » Sat Mar 21, 2009 11:29 am
Crusader Wrote:https://lastpass.com/help.php?topic=otp&fromwebsite=1
That is one way around it but it still unlocks the entire vault, Ideally what i'm after is a second vault under the same account I can see that being particularly useful if anyone for instance may use lastpass at home and then at work.
So you login to last pass and it allows most of the sites, but then you have some that are protected by a second different password for extra security.
dragon2611
Return to Feature Requests
Users browsing this forum: No registered users and 36 guests
