Grid even in offline
Postby disPlay » Tue Aug 31, 2010 6:31 pm
Why there is not a setting to turn on the grid even in offline mode?
disPlay
Re: Grid even in offline
Postby JoeSiegrist » Wed Sep 01, 2010 9:58 am
Because we don't have a way to check the grid coordinates offline, and if we included a method to check your grid coordinates offline it could be easily broken.
What we offer instead is preventing offline from being allowed (or LastPass Icon -> Tools -> Clear Local Cache if you want to clear up your saved local data).
Postby disPlay » Wed Sep 01, 2010 10:47 am
Thanks for the answer. MY really problem is the other option to enable mobile devices do bypass the grid. If a hacker can get my master password the last defense layer will be my grid but if he tries to access the database truth a mobile device only with the master password he will get it. I can't disable that option because I need it. I use the mobile version of the website allot of times to see my database. There is no way to enable the grid in the mobile version of the website?
disPlay
Postby disPlay » Sun Sep 05, 2010 4:48 pm
Joe can you tell-me something from what I said?
disPlay
Postby brantgurga » Mon Sep 06, 2010 12:22 am
I believe you can restrict mobile access to only your device.
brantgurga
Postby Lars » Mon Sep 06, 2010 12:28 am
Security is always a balance between ease of use, convenience, level of security and risk.
Lars
Postby disPlay » Fri Sep 10, 2010 7:09 am
brantgurga Wrote:I believe you can restrict mobile access to only your device.
I tried but unfortunately I don't see any way
disPlay
Postby brantgurga » Fri Sep 10, 2010 7:46 am
Did you look at the settings page described here: http://helpdesk.lastpass.com/account-se ... ile-login/
brantgurga
Postby disPlay » Fri Sep 10, 2010 6:12 pm
brantgurga Wrote:Did you look at the settings page described here: http://helpdesk.lastpass.com/account-se ... ile-login/
The problem is that the mobile websites are not capable of doing this. that is the case I only use the website to view my database since the phone is not a smartphone
disPlay
Postby disPlay » Sat Sep 11, 2010 6:00 pm
The grid authentification method is not showed also on lastpass ieanywhere.
disPlay
Return to Feature Requests
