Show Matching Sites - One Click!
Postby joelme333 » Sun Nov 04, 2018 2:47 pm
An improvement that would make LP easier to use -- Whenever there is a matching website (the password already saved), the AutoFill option should be on the first dropdown, instead of navigating thru a couple clicks.
joelme333
Re: Show Matching Sites - One Click!
Postby jpenny84 » Sun Nov 04, 2018 9:14 pm
You can easily select a login by using the field icons. If you want to use the LastPass icon menu instead, you can configure the extension to show matching sites in the top level menu in the extension preferences.
jpenny84
Postby joelme333 » Sun Nov 04, 2018 9:25 pm
aha! thanks!
joelme333
Postby jhuk » Mon Nov 05, 2018 3:19 am
Tried both way and as manual states that was old way of doing so previous builds.
Not sure which method I prefer TBH.
jhuk
Return to Feature Requests
