OKTA MFA
OKTA MFA
Postby inkjet » Thu Mar 29, 2018 9:55 am
Add Okta as a MFA choice or SAML login integration.
inkjet
Re: OKTA MFA
Postby KorinDallas » Fri Oct 05, 2018 10:12 am
+1
Can't understand why this isn't available. Okta Verify is one of the leading multifactor authentication products on the market. Lastpass is way behind the curve on this.
KorinDallas
Re: OKTA MFA
Postby wr996 » Wed Jan 23, 2019 6:43 pm
I'd really appreciate this as well. We're using Duo just for MFA now. Just supporting a generic TOTP option would allow us to use Okta Verify even without the push notifications.
wr996
Re: OKTA MFA
Postby jpittman6030 » Tue May 14, 2019 9:51 am
Not sure if this will work long-term as it is a hack, but if you scan the barcode that's generated by LastPass for google authenticator using Okta Verify, you can use it as your MFA :)
jpittman6030
Re: OKTA MFA
Postby KorinDallas » Wed Aug 14, 2019 4:07 pm
Still no reply or acknowledgement from LastPass on this limitation. Seems like they think if they just ignore it, it will go away.
Yes, you can use the Google auth barcode to set up Okta Verify, but you lose Okta's push feature and it's confusing for users to set up MFA in such a non-intuitive manner (by choosing a provider that differs from their actual authentication provider), and this makes training much more difficult than it should be.
KorinDallas
Return to Feature Requests
Users browsing this forum: No registered users and 29 guests
