Trans-border protection aka Travel Mode
Postby m965 » Tue May 23, 2017 10:34 pm
1Password has just released Travel Mode that allows you to nominate a subset of login credentials that are accessible when you are travelling (e.g. through border control where you may be asked / compelled to divulge login credentials). You are locked out of the rest until it's safe for you to access them (once you've cleared border control).
Seems like a good idea. Is LastPass planning to develop a similar solution?
http://boingboing.net/2017/05/23/logins-all-the-way-down.html
m965
Re: Trans-border protection aka Travel Mode
Postby bgif » Wed May 24, 2017 4:18 pm
+1 This could be incredible valuable as a security feature
bgif
Postby idea960 » Sat May 27, 2017 5:19 pm
I was all set to move to 1Password for this new Travel mode and better support for security questions.
Then I noticed they don't support Chromebooks.
idea960
Postby jd996 » Wed May 31, 2017 10:44 pm
+1 for some support here on a similar or better feature!
jd996
Postby aalecs763 » Thu Jun 01, 2017 4:30 am
Thumbs up for getting this feature in LastPass :)
aalecs763
Postby maxcanis » Fri Jul 21, 2017 9:52 am
+1 for Travel Mode in LassPass
maxcanis
Postby countrock » Fri Aug 04, 2017 12:42 pm
This is very much needed!
countrock
Postby grizzly » Fri Oct 20, 2017 9:57 am
Five months have passed, is Travel Mode on the LastPass roadmap? A sorely needed feature for anyone who travels.
grizzly
Postby ihartley » Fri Oct 20, 2017 11:34 am
What's the point?? The US, for example, will see immediately all your important passwords are missing. You're still with-holding the info. It would only ever work if the physical data isn't on your device, not just protected with another password.
Otherwise just delete your LP app/extension before you land. Then who can ever tell you have a LP account. Occam's razor at its best!
ihartley
Postby avolition » Mon Oct 29, 2018 3:35 am
With many countries implementing laws that allow the arbitrary imaging of innocent peoples devices simply because they are travelling, the ability to remove selected information from a device is the type of feature that any privacy / security related service should consider mandatory. How long until a travel mode will be implemented?
avolition
Return to Feature Requests
Users browsing this forum: Google [Bot] and 18 guests
