Fallback to lastpass pocket
Postby muellthos » Mon Jul 13, 2009 5:59 am
Here is my feature request:
If the website is not reachable, use the data in the pocket application.
Rationale: I'm working as a technical support person. I have to login to dozens of customer devices. To reach these devices I have to use VPN or SSL connections, which prevent the access to the web (with good reason !!!). Without connection to the lastpass website I can't access my stored information, making the service useless for me right now. If the browser could fall back to using the pocket application for Information retrieval, this would help a lot. So I could download the data from the web to the pocket application, when I'm connected to the web. If I have to connect via VPN/SSL connection to the customer, I would start the pocket, and could use the data from there.
Best regards
Thomas
muellthos
Re: Fallback to lastpass pocket
Postby h0pc » Mon Jul 13, 2009 11:54 am
I'm pretty sure the plugin uses the cached data on your computer, so if for some reason you can't get to lastpass.com, you can continue using LP. I suppose you could test it by blocking lastpass.com in your firewall to see what happens.
-E
h0pc
Return to Feature Requests
Users browsing this forum: No registered users and 10 guests
