Hi everyone,
i'd like to share my feedback on a professional usage. I am an IT Consultant and work with cloud based solutions. All our customers use cloud sites which are all hosted on similar domains at the vendor level. Hence, only a portion of the URL changes from one customer to the next.
The problem I have is that apparently, if I am currently on a browser tab and try to launch a site which is on the same domain, then it won't load it (in another tab or in the current tab). This requires me all the time to do a Ctrl + T to open a blank tab before I can then search for my customer's URL and launch it.
In a professional environment like I describe, this is an extra step I have to do hundreds of times everyday and is really annoying.
Could anyone else share his/her feedback as well? Do you think that would be worth asking for an update on this?
Thank you everyone,
Cheers
Nicolas
