Last Pass Extension overrides native fetch
Postby jamesmfriedman201 » Fri Oct 26, 2018 5:59 pm
The last pass extension overrides the native window.fetch. It should only patch it if it is unavailable.
This has unintended consequences for some codebases and took me forever to track down.
jamesmfriedman201
Re: Last Pass Extension overrides native fetch
Postby nafrack543 » Tue Oct 30, 2018 12:04 am
Yep. And as noted in my own post, does not retrieve properly when there are multiple user logins for the same site.
Also, I think that LastPass prefers to ignore subdomains, because I have to manually add to the vault for x.mydomain.com and y.mydomain.com when www.mydomain.com already has an account and password stored. Password updates go awry with this too.
nafrack543
Postby jpenny84 » Tue Oct 30, 2018 1:09 am
nafrack543 Wrote:Yep. And as noted in my own post, does not retrieve properly when there are multiple user logins for the same site.
Also, I think that LastPass prefers to ignore subdomains, because I have to manually add to the vault for x.mydomain.com and y.mydomain.com when http://www.mydomain.com already has an account and password stored. Password updates go awry with this too.
LastPass has always by default matched by second level domain. Use URL rules if you need to separate logins within a certain domain.
https://support.logmeininc.com/lastpass ... s-lp040008
jpenny84
Postby jamesmfriedman201 » Wed Oct 31, 2018 9:48 am
I don't want this to get off topic. I'm specifically talking about a code level issue for developers.
Last pass should NOT override window.fetch under any circumstance other than polyfilling it if it is not available. Currently, it overrides the native fetch in browsers that have it. I would like the developers to chime in on this.
jamesmfriedman201
Return to Feedback
Users browsing this forum: Google Feedfetcher, Rooster76 and 25 guests
