Download Entire Xmarks User Database
Xmarks support forums
Postby RRRitchey » Fri Apr 06, 2018 2:26 pm
Does anyone know of a way to download your entire database of bookmarks back to when you started Xmarks other than one at a time?
Thanks,
RRRitchey
Re: Download Entire Xmarks User Database
Postby ShawnElseworth » Tue Apr 10, 2018 1:38 am
I don't think there is a way to do this. You probably have to do it one by one.
ShawnElseworth
Postby ITechGeek » Tue Apr 10, 2018 1:51 pm
You can export them to html. Most sites will import that format.
ITechGeek
Postby rbsummers2 » Sun Apr 22, 2018 7:37 pm
I couldn't find a way to download them all. Since mine had hundreds listed, I just went through and downloaded every 50th version. I figured that should cover anything I needed to go back and look at.
rbsummers2
Return to Xmarks
Users browsing this forum: Google Feedfetcher and 6 guests
