RSS feeds chaged to folders
Xmarks support forums
Postby jmiettin » Tue Oct 31, 2017 4:29 am
Hi,
I just found that Firefox shows only folders in my toolbar not RSS feed.
Also I found in online database same failure. Now there is with same name RSS and folder. Even I remove folder from online, I can't get RSS feed.
jmiettin
Re: RSS feeds chaged to folders
Postby al789 » Fri Nov 03, 2017 4:22 am
I have the same issue with the latest version xmarks 4.5.0.4 and FF 56.... all my rss now is a empty folders... When did you resolve that issue?
al789
Postby rofdd » Fri Nov 03, 2017 8:12 am
The same problem with my Firefox: each rss feed is converted to an empty folder at uploading to Xmarks server. I'm running FF 56.0 under Linux Mint 18, Mint 17 and FF 52 ESR 32 bit under W10. Xmarks seems not to be able to handle dynamic links/bookmarks anymore. Problem started between Oct 29 and Nov 1.
Maybe I'll use Xmarks again, after there will be a solution.
Rof
rofdd
Postby al789 » Fri Nov 03, 2017 8:48 am
Hi rofdd,
I have the same OS, linux mint 18.3, windows 7 exactly the same situation... The question is, this is a bug or not supported anymore... Have you any alternative for xmarks?
al789
Postby rofdd » Fri Nov 03, 2017 9:11 am
Hi al789,
I'm testing the EverSync add-on and after that the native FFsync from mozilla. The first seems to work with different browsers...
regards, rof
rofdd
Postby jim356 » Fri Nov 03, 2017 10:37 am
Having the same problem, suddenly can't sync RSS. It used to work and now only sends an empty folder to the server for each RSS feed. There doesn't seem to be anyone at Xmarks acknowledging this problem.
jim356
Postby JPaul911 » Sun Nov 05, 2017 3:47 pm
Hi
Same thing for me, no more RSS, replaced by folders. I'm on Firefox 56.0.2, windows 10.
I hope we'll be heard
Cheers
JPaul911
Postby lgretton » Wed Nov 08, 2017 5:34 am
Same problem for me. I had to disable XMarks for the last few days due to the problem with getting dozens of login windows. I re-enabled it yesterday and was able to log in again. This morning it told me there was a problem and I could see that many bookmarks were missing. I rolled back to a previous backup only to find that every RSS feed is now just an empty folder (and I have dozens of these).
I've gone back as far back as September to try to restore them but they're all the same so it's looking very much like LastPass has completely broken the whole lot.
lgretton
Postby al789 » Wed Nov 15, 2017 12:41 pm
rofdd Wrote:Hi al789,
regards, rof
Hi,
I tested EverSync, and it's the same problem with RSS after send to the server and try download on other computer I received empty folder :((((((
al789
Return to Xmarks
