Will Opera be supported soon?
Xmarks support forums
Postby tsmith35 » Wed Jun 24, 2015 1:09 pm
I've used Firefox for a long time, but I've found Opera to be a very nice (and fast) browser. Unfortunately, there is no Xmarks extension available for Opera. Do you have any plans to provide an Opera extension?
It would be handy to be able to bookmark stuff in Opera and have it available on Xmarks. The only way I've found to get Opera bookmarks into Xmarks is to copy the URL from Opera, paste it into FF/Chrome/IE and then sync. I'll admit I occasionally use LastPass to save bookmarks (Tools > Save All Entered Data) if I'm in a hurry, but it's an awkward way to do it.
I remember there was some issue with Opera's bookmark format being proprietary some years back. If that's still an obstacle, just provide an Xmarks toolbar or toolbar button that will open up a separate set of bookmarks. Sure would beat copy'n'paste...
tsmith35
Re: Will Opera be supported soon?
Postby xmoondoggx » Fri Jul 24, 2015 12:47 am
Install the 'Download Chrome Extension'. This will give Opera the ability to install extensions from the Chrome Web App store, including Xmarks. Opera versions 15+ are built on the same Chromium platform as Chrome, and use the same extension format
https://addons.opera.com/en/extensions/ ... display=en
Xmarks
https://chrome.google.com/webstore/sear ... extensions
MD
xmoondoggx
Postby atompkins74 » Wed Aug 26, 2015 3:26 pm
Thank you, this is awesome :)
atompkins74
Postby ThatPCTech » Wed Dec 14, 2016 1:33 pm
Thanks xmoondoggx, you're the best.
Post by xmoondoggx » Fri Jul 24, 2015 12:47 am
https://addons.opera.com/en/extensions/%20...%20display=en
Xmarks
https://chrome.google.com/webstore/sear%20...%20extensions
Not only did your suggestion fix my xmarks problem, it helped me pull my other chrome extensions from google. Bam! I can cut the Google cord now. You're awesome
:D :D :D :D
ThatPCTech
Return to Xmarks
