Spunk Integration
Spunk Integration
Postby somethinglikethat » Tue Apr 02, 2019 2:39 pm
I'm having some difficulty getting lastpass Splunk Integration over their HTTP Event Collector.
I have the Splunk Instance Token and Splunk Instance URL entered on the Enterprise Options page, but am still not receiving any logs on the Splunk side. Is there anything I could be missing on the LastPass side? I'm working with Splunk support to try and figure out if that half is at fault.
somethinglikethat
Re: Spunk Integration
Postby Lpcheck41 » Fri Jul 26, 2019 11:13 am
Hi, Is this issue got resolved? If so, please post the method or findings of how you solved this. I'm facing the similar issue. Thank you
Lpcheck41
Postby somethinglikethat » Fri Jul 26, 2019 12:53 pm
Unfortunately, I was told this was not supported for the cloud version of splunk.
somethinglikethat
Return to LastPass Enterprise
