ADFS Loop
ADFS Loop
Postby vucit » Thu Jan 17, 2019 12:54 pm
Hello,
I am not finding any errors in the even viewer or the c:\programdata for Last pass, but we have setup everything for use for ADFS, and when the user attempts to login to the extension, it takes them to our adfs page, they log in, takes them to the lastpass connection page but then redirects them back to our adfs url with a blank page that says working... on the tab.
Any thoughts? Vague I know, but this is all I have to go on.
vucit
Re: ADFS Loop
Postby osbistonium54 » Tue Apr 16, 2019 12:43 am
Hi Vucit,
This link is quite helpful for troubleshooting: https://support.logmeininc.com/lastpass/help/troubleshooting-active-directory-federation-services-ad-fs-lp010072 check under the "Blank screen after logging in as a federated user" troubleshooting section.
Have you tried checking if the LastPass secret attribute is being populated in AD?
Also check that the attribute is specified in both the LastPass AD Connector installer and in the Admin portal.
This is an old post, so you've probably resolved it.
osbistonium54
Re: ADFS Loop
Postby jpamhrn » Sat Sep 07, 2019 7:12 am
Hi vucit,
I don't want to hijack someone's post, but I'm having the same issue. What do you mean by Also check that the attribute is specified in both the LastPass AD Connector installer and in the Admin portal. And especcialy the part about the AD connector?
jpamhrn
Return to LastPass Enterprise
