Other Enterprise admins using DUO - experience
Postby cbowers572 » Mon Dec 03, 2018 6:38 pm
We recently transitioned to using DUO 2FA from a mix of Yubikey and Lastpass Authenticator.
That's all fine for the end users.
But we're seeing something odd in the Admin console (LP).
It seems like a session cookie expires after about ~3 minutes.
If you're searching a log, or updating something in the admin console, and you're idle for too many minutes (less than 5), you see another DUO 2FA prompt.
You can check the box in lastpass/DUO to remember me (our policy only allows an hour).
This doesn't help however.
You still see the Lastpass 2FA window come up after that short time-out, it's just that it comes up and then goes away without a prompt.
However you lose what you were working on and get dumped back at the top of the admin console.
If you were refining a log search, you lose where you were. If you were saving an SSO setup record and hit save, the save isn't kept.
Are others seeing that?
cbowers572
Return to LastPass Enterprise
Users browsing this forum: No registered users and 10 guests
