Last Pass incorrectly filling password as both login and pas
Postby Rickyp7425 » Sun Apr 08, 2018 8:45 pm
I am having an issue logging into my ADP 401k account. Last pass incorrectly generates the login and password. It uses the password for both forms. I have tried several different methods of saving the url, login, password with no solution.
https://www.mykplan.com/sponsorsecure_net/login.aspx
Rickyp7425
Re: Last Pass incorrectly filling password as both login and
Postby jpenny84 » Sun Apr 08, 2018 9:04 pm
It's likely because the field they're using for the user ID has a password attribute. Are you able to manually capture the correct field information using Save All Entered Data?
https://helpdesk.lastpass.com/adding-a-site/
jpenny84
Postby Rickyp7425 » Sun Apr 08, 2018 9:29 pm
Thank you that worked
Rickyp7425
Return to LastPass Enterprise
Users browsing this forum: meyer506 and 6 guests
