Icon greyed out, won't open
Postby ireneazanderson636 » Tue Apr 04, 2017 12:27 pm
I have a Mac and am using Safari. In the past few days, the last pass icon (three dots in toolbar) are grey and I cannot open last pass from there. I can open it from the icon in the bottom toolbar. Thanks
ireneazanderson636
Re: Icon greyed out, won't open
Postby GreenDrake » Sat Jul 22, 2017 7:06 pm
I'm having the same problem. I just upgraded to v. 4.1.45. Nothing happens if I click on the light gray "...|" icon. I don't know how to attach a .pdf here but If I click and hold, I get a dropdown that says: "LOGOFF", then: "Search all data", then: "Vault Save Site Add Note" and then, further down: "Sites Folders FormFill Generate Advanced" . I'm not sure where to go from here but at the moment, LastPass is totally worthless for me.
GreenDrake
Postby joco725 » Mon Aug 07, 2017 1:33 am
i have the exact same problem as described here. LP v4.1.61.121, Safari v10.1.2, Sierra v 10.12.6
joco725
Postby andyc111 » Mon Aug 14, 2017 11:59 am
Mine was grayed out as well on Safari. I just went to Safari>Preferences>Extensions and clicked the check box on and off for LastPass. It worked after that, hope this helps.
andyc111
Postby PdD » Thu Aug 17, 2017 11:10 am
Thanks, Safari>Preferences>Extensions and clicking the check box on and off for LastPass worked for me as well.
PdD
Postby surevapes550 » Wed Sep 13, 2017 11:14 am
I too am having the same greyed out button issue in Safari on both an iMac and MB Pro.
surevapes550
Postby govindalila89 » Wed Feb 14, 2018 8:12 pm
Thanks, Safari>Preferences>Extensions and clicking the check box on and off for LastPass worked for me as well. Appreciate it!
govindalila89
Postby helpwanted » Wed Feb 21, 2018 8:30 pm
When does LastPass plan to issue a fix for this bug? It's extremely annoying to have to go to the Safari Preferences to toggle the checkbox on and off every time I restart my Mac. C'mon customer support...
helpwanted
Postby yodi » Sun Feb 25, 2018 2:40 pm
Same problem for me, on several Macs. It's really annoying.
yodi
Postby joysslon340 » Sun Feb 25, 2018 4:56 pm
You're lucky - I can't find any icon. (*_*)
joysslon340
Return to LastPass Enterprise
