Can't add websites to shared folders
Postby servicedesk401 » Mon May 09, 2016 5:57 am
Hi,
As of today I can't add new websites too one of my shared folders. If i try to add one it will cancel itself out.
However If I add a website without selecting a map (the website will store under none) I can drag and drop to add the website to a shared folder.
Any idea on how this is possible?
servicedesk401
Re: Can't add websites to shared folders
Postby dmitrijLP » Mon May 09, 2016 10:29 am
servicedesk401 Wrote:Hi,
How do you originally try to add/move the login? What browser are you using? All permissions are correct for you on your shared folder?
I tried to move a login and save a new one straight into the shared folder using Chrome, no issues.
Please try this basic steps to see they helps:
1. Click on the LastPass Icon > More Options > Advanced > Clear Local Cache.
2. Once again click on the LastPass Icon > More Options > Advanced > Refresh Sites.
3. Log off from the LastPass extension, restart the browser and log back in.
dmitrijLP
Postby servicedesk401 » Mon May 09, 2016 11:29 am
Hi Dimitri,
I tried your steps, however they did not seem to work.
I try to add a site by clicking the + icon in the right corner. Then type in name,url etc.
On Map I select the map that I want the site to appear which is a shared folder.
When I do this I get the message: website added successful. however, there is nothing added....
servicedesk401
Postby dmitrijLP » Mon May 09, 2016 1:49 pm
servicedesk401 Wrote:Hi Dimitri,
Appreciate the additional details, this appears to be an issue only with online vault, I have reported this to developers to have it addressed asap.
For now, if you need to perform this actions, please try using the local vault via LastPass icon --> My LastPass Vault, same steps should work correctly.
dmitrijLP
Postby servicedesk401 » Tue May 10, 2016 6:21 am
alright it is working now!
Thanks for the great support again Dimitri.
Cheers and have a nice day.
servicedesk401
Return to LastPass Enterprise
