Editing LP with CSV File
Postby StrategicDirect » Sat Sep 01, 2012 1:03 pm
I would like to export my LP file to CSV and edit and reorganize it there, then re-import the corrected updated file to LP and overwrite the previous version. Is this possible? If yes, should I be leaving CSV colunms in same order as the original export, or is ther a field mapping tool for importing the updated file?
StrategicDirect
Re: Editing LP with CSV File
Postby Lars » Sat Sep 01, 2012 1:50 pm
Yes, go to Tools, Export To
It always pays off to read the manual.
Lars
Postby StrategicDirect » Sat Sep 01, 2012 3:57 pm
Thank you Lars. Having read the manua before my post, it is informative about export to CSV, but I find no reference to a reimport of the revised CSV file or if it would overwrite the original LP source file with the update.
http://helpdesk.lastpass.com/tools/exporting/
Perhaps you can direct me to the link you referred to.
StrategicDirect
Postby jonat » Tue Sep 04, 2012 11:25 am
There is a corresponding "Generic CSV File" source at Tools > Import From... My understanding is that this will add entries, not replace any existing ones, so perhaps you'd want to delete the old entries first.
jonat
Return to Off Topic
