LastPass with Sea Monkey browser
Postby jstevenson3998649 » Thu Apr 06, 2017 7:30 pm
I've been using LastPass on the Safari browser and it works -- that is to say the it helps at least a little when logging into password-protected sites -- but now I'm trying to use the Sea Monkey browser. I can log into LastPass from Sea Monkey and launch sites from there, but then I have to type in all the logins and passwords manually. There's no toolbar widget, nothin. The only use I get from LastPass on Sea Monkey is as sort of a password depository where I can go see what my login or password is, jot it down, and then return to the site I want to enter -- i.e. not much good at all. Can somebody help? there's gotta be a way. Maybe a special plug-in I need? Thanks. Joseph
jstevenson3998649
Re: LastPass with Sea Monkey browser
Postby jpenny84 » Thu Apr 06, 2017 8:48 pm
Seamonkey is not officially supported. If you cannot install the LastPass extension from the add-on store and get it to work, you may have to switch to a supported browser.
https://lastpass.com/support.php?cmd=showfaq&id=8886
jpenny84
Postby jstevenson3998649 » Thu Apr 06, 2017 11:41 pm
What is the "add-on" store? Where can I find it?
jstevenson3998649
Return to Off Topic
