Language issue
Language issue
Postby yochadwick » Wed Apr 16, 2014 10:49 pm
I would really like to use and perhaps upgrade LastPass. However, I can't get anywhere due to the language. How can I change it to English. I can click the icon (as the help page suggests) but I can't click Preferences, etc. if I can't read that language. ???
I have removed the plugins and redownloaded again to be sure I hadn't gotten trigger happy during the install. No luck though. I'm using OSX 10.9.2 with latest versions of Firefox, Chrome, and Safari.
Please help.
yochadwick
Re: Language issue
Postby jpenny84 » Wed Apr 16, 2014 11:27 pm
jpenny84
Re: Language issue
Postby yochadwick » Thu Apr 17, 2014 12:07 am
Thanks but I'm not using Windows and I have uninstalled and reinstalled on the Mac.
yochadwick
Re: Language issue
Postby jpenny84 » Thu Apr 17, 2014 1:17 am
Per the link above, check the language settings by going to LastPass icon > Preferences > Advanced.
There's a setting in your account options as well.
https://helpdesk.lastpass.com/account-settings/general/
jpenny84
Re: Language issue
Postby yochadwick » Thu Apr 17, 2014 7:14 am
Thanks. It appears to be a problem within Firefox (28.0 Mac) on my computer. The plugin works fine in Safari and Chrome. As you can see in the screenshot, changing the setting on the web site didn't help. I put a copy of Firefox and Chrome side by side on my screen to find the appropriate setting in Firefox. I chose English and it changed the web page language to whatever is shown in this screen shot. Not English. Very odd. As a reminder, the plugin has been uninstalled, program restarted, and plugin reinstalled.
Plugin
Web site after finding and changing language to English
yochadwick
Re: Language issue
Postby jpenny84 » Thu Apr 17, 2014 12:37 pm
Did you go to Lastpass Icon > Preferences > Advanced in the extension to check the language configuration?
Your LastPass extension preferences for Firefox are in the preferences.js file and will stick around even if you delete LastPass. You can either dig around in about:config to find the language default or just delete your prefs.js which will reset any browser preferences including those for LastPass to the default.
LastPass on Chrome uses the default browser language. That's why you're not seeing an issue. I'm not familiar with the Safari extension.
http://kb.mozillazine.org/Resetting_preferences
jpenny84
Re: Language issue
Postby yochadwick » Fri Apr 18, 2014 12:43 am
I did use the icon. I didn't think about looking under about:config. That mod did the trick. Thanks. :)
yochadwick
Re: Language issue
Postby daviddelrey » Sat Jul 19, 2014 10:00 pm
That's Hebrew.
daviddelrey
Return to Off Topic
