Chrome + LP V2.5.26 Extension Crash Changing Amazon Password
Postby iandol » Fri Oct 25, 2013 7:50 am
Hi, when logged into amazon.co.uk trying to change the account password LastPass correctly finds and fills in the previous password field and the generate password field popup works, but when you go to change the password the extension crashes before it changes the vault site details and so the amazon password will be changed but not the vault entry. Luckily (good planning on your part I suspect), the generated password is saved as a new vault entry before the crash occurs, so you can then manually recover and edit the details.
What is the best way to provide you guys with more debug info. This extension crash is repeatable (happened twice anyway)...
Chromium 32.0.1680.0
iandol
Re: Chrome + LP V2.5.26 Extension Crash Changing Amazon Pass
Postby iandol » Fri Oct 25, 2013 3:05 pm
Here is what I think are the crash logs, when using the background.html console log it closes when LP crashes but on restart the first set of text is present in the console, probably it is not the previous session's info but just in case. The second log is taken from the general console.log on crash and it directly related to the crash but contains less info:
https://gist.github.com/iandol/7159992
[EDIT: first log isn't from the crash, but errors on reloading the extension after the crash]
iandol
