LastPass for IE10 Enhanced Protected Mode
Postby JamesG269 » Thu Mar 08, 2012 10:24 am
I realize Win 8 CP is new, but I'm wondering if you guys are looking at Enhanced Protected Mode and have figured out a way to support it. Enhanced Protected Mode is an option in IE10 (x64 only I think) that runs IE10 in a more secure sandbox called AppContainer (same as metro apps run in, even though it's for IE10 desktop), and currently lastpass doesn't work on any site that has it enabled (it can be disabled via a prompt when a site wants to load flash, to fall back to the standard protected mode sandbox.) Apparently EPM does support plug-ins, but they must be made compatible and marked as so.
JamesG269
Re: LastPass for IE10 Enhanced Protected Mode
Postby Lars » Thu Mar 08, 2012 1:18 pm
Not sure about Win 8 etc, but I run my Firefox / LastPass combo in Sandboxie and it works flawlessly.
Lars
Postby jessehouwing » Sun May 06, 2012 12:57 pm
I crave for Windows8 Metro IE support. Entering passwords using the on-screen keyboard is a pain...
jessehouwing
Postby JamesG269 » Thu Nov 29, 2012 6:24 pm
Is there any update on the topic of this thread, LastPass for IE10 Desktop in Enhanced Protected Mode?
JamesG269
Postby bronekk » Tue Apr 29, 2014 5:10 am
I would like to be able to use LastPass in IE11 with EPM enabled ... there's been recent vulnerability in IE http://www.cve.mitre.org/cgi-bin/cvenam ... -2014-1776 and one way to protect against it is to enable EPM. But I also want to continue to use lastpass!
bronekk
Postby jpenny84 » Sat May 03, 2014 7:23 am
bronekk Wrote:I would like to be able to use LastPass in IE11 with EPM enabled ... there's been recent vulnerability in IE http://www.cve.mitre.org/cgi-bin/cvenam ... -2014-1776 and one way to protect against it is to enable EPM. But I also want to continue to use lastpass!
An out of band emergency patch was released for that vulnerability on Thursday. If you have automatic Windows updates enabled, your computer should have installed it by now, but you can verify by running Windows update.
jpenny84
Postby tongclub60246 » Wed Jan 28, 2015 4:52 am
I crave for Windows8 Metro IE support. Entering gclub passwords using the on-screen keyboard is a pain.
tongclub60246
Postby jpenny84 » Wed Jan 28, 2015 3:57 pm
tongclub60246 Wrote:I crave for Windows8 Metro IE support. Entering gclub passwords using the on-screen keyboard is a pain.
The Metro version of Internet Explorer does not support extensions or bookmarklets. Copying passwords from the Metro app would be your best bet.
https://lastpass.com/support.php?cmd=showfaq&id=3465
jpenny84
Postby scotthill » Sat Feb 28, 2015 1:09 am
Not have much idea about it .
scotthill
Postby teddy89ploth268 » Mon Apr 06, 2015 10:03 pm
i want to know to, thank for sharing ibc
teddy89ploth268
