Where have all the pre-builds gone?
Postby streetwolf » Thu Apr 23, 2009 12:50 pm
Not that they aren't available, you just have to know the link. I've been using the pre-builds since 1.50 came online.
Would it be possible to have a thread containing a link to the latest pre-build and also what changes were made?
streetwolf
Re: Where have all the pre-builds gone?
Postby JoeSiegrist » Thu Apr 23, 2009 1:32 pm
We're finally overhauling this and should have a prebuild out tomorrow that is 1.50.1, our plan is the update the second number for major builds and the 3rd number for pre-builds -- once you're running the prebuild you'll update automatically and we'll keep the latest release notes at https://lastpass.com/upgrade.php
For now:
IE/Installer: https://lastpass.com/lastpasspre.exe
Firefox: https://lastpass.com/lppre.xpi
Postby streetwolf » Thu Apr 23, 2009 2:25 pm
sounds great
streetwolf
Postby TheOne-JC » Mon Dec 10, 2012 7:06 pm
Joe,
Same question here, where have they gone?
Still, 2012 & they are not available....please help..... every time I click on the ones sent by you or other support lastpass person, it does not update to a prebuild, it remains as my same version, which is the one you have on your lastpass site.
JC.
TheOne-JC
Postby jpenny84 » Mon Dec 10, 2012 7:26 pm
Even the link provided here? You will need to look at the build date (LastPass Icon > Tools > About) and not necessarily the version number, especially with Firefox.
https://lastpass.com/lpp/
jpenny84
Postby TheOne-JC » Mon Dec 10, 2012 8:55 pm
jpenny84 Wrote:Even the link provided here? You will need to look at the build date (LastPass Icon > Tools > About) and not necessarily the version number, especially with Firefox.
Yeap! same thing..... unless you guys are still on version 2.0.0, but are just changing built dates, if that is the case, then maybe it is updating it, it shows 12/2 as the built date....is that the last one for your prebuilds?
JC.
TheOne-JC
Postby jpenny84 » Mon Dec 10, 2012 10:03 pm
I'm just a user - I don't work for LastPass. If I install the prebuild, I'm showing a 12/4 date, but I use a Mac, so the Firefox extension could be different.
jpenny84
