Firefox Nightlies x64
Postby magcius » Mon Nov 01, 2010 4:34 pm
Using the Firefox Nightlies it seems that LastPass freezes
the browser for about a minute on startup. If I disable
LastPass and restart the browser, it doesn't seem to happen.
I'm using the LastPass prebuild: http://lastpass.com/lppre.php
Version: 1.70.1
Built: Oct 29 2010 14:11:36
Fast Encryption: false
Are you falling back to JS encryption if it can't use a
binary version?
magcius
Re: Firefox Nightlies x64
Postby JoeSiegrist » Mon Nov 01, 2010 5:41 pm
We do fall back to javascript based encryption (with Firefox 4 this is a lot faster than it used to be)... Do you have over 1000 accounts? It shouldn't take more than a few seconds regardless.
Postby magcius » Mon Nov 01, 2010 6:09 pm
It's gotten very slow with recent Firefox changes.
I would think it's a bug in the extensions system.
It doesn't happen on Linux though, so it could be
something with the drawing code on Windows.
magcius
Postby Sir_Sid » Tue Nov 16, 2010 9:08 pm
I can confirm this exact problem in beta 7 on windows.
Linux nightlies perform fine however.
Sir_Sid
Postby dicks » Mon Nov 22, 2010 3:56 am
I installed Firefox 4b7 next to 3.6 and have the issue that Lastpass does not remember the login after I restart FF4b7. I always need to re-enter the master password to activate LP.
The pre-build build number is still 1.70.0 - where did you download 1.70.1?
dicks
Postby magcius » Mon Nov 22, 2010 8:04 am
The link is at http://lastpass.com/lppre.php
The version info in the Add-ons window lies: go to the LastPass Menu->Tools->About
magcius
Postby dicks » Mon Nov 22, 2010 8:08 am
Got it.
Release is Oct 16, 2010 and not as quoted above... ???
dicks
Postby brain_x64 » Mon Mar 21, 2011 1:44 pm
lastpass login session is not stored after browser restart i need to login every time again even if configured to save it in the options
LastPass Firefox Menüleiste
Version: 1.73.0
Erstellt am: Mar 14 2011 23:25:47
Schnelle Verschlüsselung: wahr
Copyright 2008-2011 LastPass. Alle Rechte vorbehalten.
Teile dieser Software stehen unter Lizenz Dritter wie erläutert unter:
https://lastpass.com/docs/licenses.php
brain_x64
Postby brain_x64 » Thu Apr 28, 2011 8:41 am
hi, the problem still in firefox 6.0a1 and current lastpass nightly exists!
Version: 1.73.0
Erstellt am: Apr 26 2011 13:15:30
brain_x64
Postby MalarKeY007 » Thu Apr 28, 2011 3:20 pm
The same thing is happen with me....
It took 1 minute to begin the navigation...
Versão: 1.73.0
Compilado: Apr 27 2011 17:44:05
Anyway, Thanks to all LastPass Team for the great work and for updating the addon very quickly with Nightly Build!
MalarKeY007
