LastPass for Apps - first go
Postby larsjo » Mon Jun 07, 2010 6:40 am
Hi PreBuild Team,
I started testing the LastPass for App. (1.68.0)
I am using the YubiKey and logging in is fine.
I have found the following bugs:
1. No App. refresh on startup - need to do this manually.
2. Can't edit details on the app. placed at the top of the app list.
3. Inside the Edit App. Info: Clicking OK - will "Sometimes" not save changes.. (The AutoFill tab only get saved if I select Favorite at the same time)
4. Having multiple login/pass for the same App. will show an "AutoFill (2)" at the top of the list. (With AutoFill disabled)
5. Having multiple login/pass for the same App. will always select the top of the list login/pass. (All with Autofill enabled)
6. Inside the Edit App. Info: My application path change from c:\documents and settings\lj\desktop\app.exe to
c:\\documents and settings\\lj\\desktop\\app.exe and keeps adding the backslashes - every time I change the App Name and push "OK".
7. I also only use FF for lastpass - on startup i get the popup to install browser-plugin:
- see http://forums.lastpass.com/viewtopic.php?f=19&t=28249
8. I need a manual way to add apps.
(And no support for SSL Java Applets !)
That's all for now - Please continue the great work
Lars
larsjo
Re: LastPass for Apps - first go
Postby jhedlund » Wed Jun 23, 2010 11:39 pm
Giving this post a +1 !
I have the #2 issue too (cannot Edit the first App in the list)
And #8 would make Lastpass for Apps the most useable for me - manual addition of applications.
Jeff
jhedlund
