LP for Apps - "Out of Memory"
Postby gdkemble » Wed Apr 07, 2010 2:57 pm
Hi all,
I'm trying to add TrueCrypt as an application in LP for Apps, but when I try to finish the training I get an "out of memory" error. The dialog box says "lastapp" in the title bar. Any ideas?
The password is 34 characters long, but that shouldn't matter, right?
Any help would be appreciated.
::Update: I just tried to add another application into LP for Apps, with a much shorter password, and I got the same error.
Right now I only have 4 applications programmed into LP for Apps, so I'm not sure what's going on. Let me know what other information I can get you.
gdkemble
Re: LP for Apps - "Out of Memory"
Postby JoeSiegrist » Fri Apr 09, 2010 2:53 pm
We can't reproduce this at all -- can you try the latest build of this: https://rodan.lastpass.com/dev/lastappinstall.exe
Postby gdkemble » Fri Apr 09, 2010 3:09 pm
Thank you for your quick response.
I installed LP for Apps from the link you supplied, and I'm still getting the error message.
When I'm home I'll test to see if it happens on that computer too. I wouldn't be surprised if the problem is this junker at work.
I'll post again when I've had the chance to try it on another machine.
gdkemble
Postby gdkemble » Sat Apr 10, 2010 12:30 am
Okay, so it seems that it's the computer, not LastPass for Apps, specifically. On my computer at work, I get the "Out of Memory" error when trying to created a new entry in Applications; that does not happen on my computer at home. In the end, I'll probably just be sure to make all new entries at home (probably more secure anyway).
If you want more information about my work computer--if this resource problem is something that might happen elsewhere and you want to understand it better--let me know and I'll post information about that computer. Otherwise, I'll assume this is close enough for rock and roll.
And I want to repeat: I really like LastPass, and the LP for Apps fills in the one thing I wanted. Thanks again.
gdkemble
Postby rkoehler » Wed Jan 19, 2011 3:30 am
Same here, XP 32bit, 4GB Memory, >3GB Swap
Taskmanager - physical memory 1557000 free
After NEXT, then OK a Requester appears
lastapp
out of memory
rkoehler
Postby rjbu » Sat Feb 19, 2011 12:47 am
rkoehler Wrote:Same here, XP 32bit, 4GB Memory, >3GB Swap
lastapp
out of memory
Yes, I get the "out of memory" every time I try to add an app, too.
XP SP3 32-bit 2GB memory taskmgr says there is 1.2GB free.
process explorer shows lastapp has a virtual size of 261M;
it grows from 125M to 260M as soon as you "find" or "fill"
an application. This is with lastpass for applications 1.72.0
Bob
rjbu
