LastPass for Applications Error
Postby redgin » Mon Mar 22, 2010 8:58 am
When I try to login to LastPass for Applications, I get the error: "The parameter is incorrect."
When I click OK on the error message, I'm returned to the login dialog.
I'm using Windows XP and Internet Explorer.
redgin
Re: LastPass for Applications Error
Postby redgin » Mon Mar 22, 2010 9:12 am
It's fixed. I needed to installed the prebuild version of the IE plugin.
redgin
Postby cozzielex » Sat Feb 19, 2011 11:30 pm
Can you please help me because I am having the same problem but I dont understand your solution about the plug in for IE.
I have posted another message about this before I saw your message.
Thanks very much
Cozzielex
PS Please explain the solution in very simple terms.
Txx
cozzielex
