Cannot Uninstall Lastpass for Apps
Postby bburzycki » Tue Jan 19, 2010 9:55 pm
It seems that even after uninstalling via Uninstall a program in Win 7 64bit - the lastpass for apps still remains active in the taskbar and the only item that is uninstalled is the uninstaller itself.
Any ideas?
If somoene has the link to the pre-build beta again I can try to re-install and remove and see if that solves the issue.
bburzycki
Re: Cannot Uninstall Lastpass for Apps
Postby JoeSiegrist » Fri Jan 22, 2010 11:31 am
We've put up a fix for this if you redownload (use the original email we sent)
Postby bburzycki » Fri Jan 22, 2010 10:40 pm
I wish i actually kept that email...
bburzycki
Postby JoeSiegrist » Sun Jan 24, 2010 8:19 pm
We resent it to you...
Postby bburzycki » Sun Jan 24, 2010 8:28 pm
Yep got it and thanks
bburzycki
Users browsing this forum: MSN [Bot] and 2 guests
