App under mouse not found (LastPass for Apps v1.64.4)
Postby yllwsmly » Tue Jan 19, 2010 12:41 pm
When trying to add an application, the LastPass for Apps v.1.64.4 (build 1.18.2009) isn't "finding" it (putting the window in a red border). The application is named IAShellA.exe (Interactive Intelligence Interaction Administrator).
Thanks!
yllwsmly
Re: App under mouse not found (LastPass for Apps v1.64.4)
Postby CaryRW » Mon Jan 25, 2010 2:07 pm
Having a similar issue with Citrix XenApp Launcher.
CaryRW
Postby yllwsmly » Mon Jan 25, 2010 3:28 pm
I have uninstalled the old version and installed the latest build (1.64.4 build Jan 25 2010). With this release, the IAShellA.exe training works properly. I suggest loading the latest beta.
Thanks!
Jeremie
yllwsmly
Postby CaryRW » Mon Jan 25, 2010 4:03 pm
yllwsmly Wrote:I have uninstalled the old version and installed the latest build (1.64.4 build Jan 25 2010). With this release, the IAShellA.exe training works properly. I suggest loading the latest beta.
That is the version I am running.
Cheers...
Cary
CaryRW
Postby bob » Mon Jan 25, 2010 4:59 pm
I am not too familiar with this app, will try to get my hands on it.
One quick question, is the target app actually running on your PC or are you accessing it remotely?
Thanks
bob
Postby CaryRW » Mon Jan 25, 2010 7:19 pm
bob Wrote:I am not too familiar with this app, will try to get my hands on it.
It is running on my laptop (local application). Citrix XenApps is the locally run plug-in to access a Citrix Server. I have attached a screenshot of the About screen for your information.
Cheers...
Cary
CaryRW
