uberstrike.cmune.com
Postby Bubbly » Sun Apr 15, 2012 9:20 pm
Can someone help me to save it for this website? When I try to do it manually by pressing save website nothing happens (it does on this forum, so it's really not catching anything I guess). When I log in and then click on save website, it suddenly does! So I'm not following this really weird behavior. It does suggest my saved Facebook logins, which is probably because there's a Facebook button (but why a button would provoke the autofill bar is a mystery to me as well).
Help please.
Thanks,
Bubbly
Re: uberstrike.cmune.com
Postby formay » Thu May 17, 2012 6:00 am
here is some more info about it http://www.dotmmo.com/uberstrike-9893.html
formay
Postby Bubbly » Thu May 17, 2012 9:15 am
And this is the concerning website:
http://uberstrike.cmune.com
Bubbly
Postby Israel » Tue May 29, 2012 10:57 am
You may want to try Save All Entered Data to fix your login issues on this site. On most sites with problematic form entries, SAED can correct login issues - see here for more information : http://helpdesk.lastpass.com/login-problems/
Israel
Site Admin
Postby Bubbly » Tue May 29, 2012 8:54 pm
As you can see this totally differs from the Chrome extension used in the tutorial.
So the "Save All Entered Data" option does not exist in the Safari extension. Is there no other way to do this? :(
Bubbly
Postby Bubbly » Sun Jun 24, 2012 1:53 pm
I figured a way to do it.
1. Go to the website
2. Generate password
3. Click on save
4. It will be saved (even though the normal save website button malfunctions!)
5. Edit your generated password, replace it with the real one and add your username
6. You have to click manually. Autologin is broken, autofill is broken.
Too bad LastPass doesn't function 100%, but at least there IS a work around the work around.
Bubbly
Postby banjocuffman698 » Sun Apr 21, 2013 8:30 am
banjocuffman698
Users browsing this forum: Yahoo [Bot] and 11 guests
