nyxdata.com problem login
Postby luckman212 » Wed Apr 29, 2009 12:38 pm
Hello,
I tried every which way I know (including SAED - Save All Entered Data) and just cannot get the following site to work for Auto-Fill / auto-login:
http://www.nyxdata.com/nysedata/default.aspx
I am using LP pre-build 1.50.1 as of today 4/29/09
Firefox 3.5beta4
Any ideas?
luckman212
Re: nyxdata.com problem login
Postby JoeSiegrist » Wed Apr 29, 2009 6:13 pm
SAED worked for me -- delete the extra stuff at the end of the URL so your URL is: https://www.nyxdata.com/nysedata/Home/L ... fault.aspx also remember to delete the search text in 'edit fields'
Postby luckman212 » Wed Apr 29, 2009 10:39 pm
Ok, I followed your steps and got it to work.
But, in the process I noticed another bug with deleting fields from a login:
when a login contains multiple fields, deleting one causes a whole bunch of them to temporarily disappear.
best way to explain this is a visual:
before:
then I delete ONE field (in this case it was the "...$tbEmail" field), and am left with this (after):
luckman212
Postby luckman212 » Fri May 01, 2009 5:07 pm
This seems to have been resolved (that is, the problem of the disappearing fields) in the final 1.51 version that was out today--- can you confirm?
luckman212
Postby JoeSiegrist » Sat May 02, 2009 10:00 pm
Confirmed -- sorry I didn't reply, thanks for finding the issue!
