spacebear Wrote:IMGrant, thanks for your quick reply. Well, I was suspecting that already. I was just hoping that someone would have found a solution to this in the meantime. Maybe something like a page recognition that doesn't take into account the field ID, but the location of the field on the HTML page.
Another thing that's worth mentioning is that upon page load, the keyboard focus is already on the login field. So maybe a simple login<tab>password<enter> input sequence like KeePass does would do the trick (I've been using KeePass before and it works perfectly there).
Ah, I didn't know that about KeePass, maybe there is hope for LastPass if the developers are reading!
