Dear Joe...
Dear Joe...
Postby Hugh » Sun Mar 01, 2009 3:01 am
Dear Joe, thanks for your response to my earlier query about why LP can't log me in to Safe-mail.
But still no luck, I'm afraid. Yes, the two fields are there and the correct info is in them. When I try to log in using LP it fills in the username OK but leaves the password box empty. The toolbar says "Lastpass has filled your login information into the form on this page" and shows the 3 buttons: "AutoLogin", "Never Autofill" and "Fix Broken". If I press AutoLogin it tries to log me in and just goes back to the same screen, as of course the pw is not there. If I fill in the pw manually it logs in OK.
I've deleted and reinstalled the site several times but there is no change.
Roboform has no trouble with the site and works fine every time. I want to get rid of RF, though, and use LP exclusively, so would appreciate any help you can offer to get Safe-mail working with LP.
Hugh
Hugh
Re: Dear Joe...
Postby JoeSiegrist » Tue Mar 03, 2009 1:24 pm
Hugh Wrote:Dear Joe, thanks for your response to my earlier query about why LP can't log me in to Safe-mail.
Can you upgrade to 1.46 and see if it resolves it? I can't reproduce the problem at all.
Re: Dear Joe...
Postby Hugh » Tue Mar 03, 2009 7:23 pm
JoeSiegrist Wrote:Can you upgrade to 1.46 and see if it resolves it? I can't reproduce the problem at all.
Have done the upgrade to 1.46, Joe, but unfortunately no change. Puzzling.
Hugh
Hugh
