site can't be saved by lastpass
Postby meir444 » Mon Jul 08, 2019 6:27 am
using chrome extension. up to date chrome version.
save all data not working, and add site manually not working.
https://www.xnes.co.il/OTPLogin/LoginOTP.aspx
meir444
Re: site can't be saved by lastpass
Postby TECH198 » Mon Jul 08, 2019 10:34 pm
Usually when i can't save via plugin, i use mobile app.
You can try removing plug and re-adding it back, just to see and/or trying "save all entered data" on another website you have login details on..
If its ok with other sites, its just the website itself.. which is not uncommon.. In that case, the only way would be to add the site via mobile/use
Alternatively, go back to a previous version where it DID work.. or try beta version: https://support.google.com/websearch/an ... 7673?hl=en
eg may sites (increasing I've seen) break Lastpass, more often then they fix, because its easy enough to do different login/popup methods which requires an 'update' of Latpass..
Since the number of broken website always will exceed the fixes Lastpass does, it will always be a problem.
That's the negative side of doing what they do
TECH198
Postby meir444 » Tue Jul 09, 2019 2:55 am
The lastpass chrome extension works with no problem on all sites, except from this one.
"save all entered data" also does not work.
I posted the URL so the lastpass team can review what method this site uses and update lastpass.
meir444
Users browsing this forum: No registered users and 20 guests
