Prevent update of combined password field
Postby DaniW1337 » Tue Jul 02, 2019 4:55 am
Hi,
1) Have you tried to save your login details using the "Save All Entered Data" feature?
-YES, and it is working
2) In what web browser are you experiencing an issue capturing your login details? Have you tried to capture your login details using different web browsers?
- Chrome, same behavior in Firefox
3) Whenever possible, please include the exact login page URL.
- ahp.cancom.de
The problem is that the "PIN und Token" field has a static part which is the pin and a dynamic part which is the token. the token is being generated with an app and will then be typed in by the user. so in the end the field consists of, for example a pin 1234 and a token 567890 and ends up as 1234567890. So Lastpass is totally right when it asks the user to update the password as it looks like it was changed. Of course in this usecase it is wrong to update the password... :?
So I tried to set a "Never URL" to "Never Add Site" for that domain but it still asks me to update the password. Is there any workaround for this?
Thanks
DaniW1337
