DocuSign MANGLES Login Address
Postby anthony975 » Mon May 06, 2019 7:34 pm
Docusign MANGES the lastpass username passed to the login page.
You can COPY the username from the lastpass menu and PASTE it into the site login but Autologin Fails .
No Auto login ends up with a pile of garbage in the login username and fails also.
Copy Paste only workaround for me.
Have used a couple of browers (Safari and Chrome OSX) with no result.
Have reset and recaptured the site as recommended in Lastpass FAQ again no result.
Lastpass work on all other sites and browsers.
anthony975
Re: DocuSign MANGLES Login Address
Postby anthony975 » Tue May 07, 2019 7:46 am
anthony975
Postby Footprint » Wed Oct 30, 2019 4:39 pm
It mangles my Docusign user name in Chrome, as well, filling in alpha/special characters. I, too, have to copy and past it in manually. Really frustrating.
Footprint
Postby ck937 » Wed Nov 06, 2019 4:52 am
I can confirm that I also experience this issue of a mangled user name with DocuSign - LastPass - Firefox.
ck937
Postby PatrickLP » Thu Nov 07, 2019 8:44 am
I can confirm this is a problem on my end as well. I've tried a NUMBER of work arounds by adding exra fields (username etc). Doesn't work.
PatrickLP
Postby PatrickLP » Thu Nov 07, 2019 8:50 am
Figured it out - here are my setting:
URL: https://account.docusign.com/username#/password
Advanced settings: autologin enabled
then click edit form fields (wrench icon)
add form field
name='email'
type='text'
field value=<the email you use to log into docusign>
add form field
name='password'
type='password'
field value=<your docusign password>
PatrickLP
Postby ttcheng » Thu Nov 07, 2019 10:18 am
Confirmed that the solution posted by PatrickLP works. I only added an "email" field. Didn't know you could add fields in LastPass--very handy! I'll be using that feature in the future. I'm guessing that the field name needs to correspond to the "input name" in the HTML. In Chrome, if you right-click on the field and select "inspect", you can see the HTML which presumably includes the field name. For example, <input name="email". Thanks for the solution, PatrickLP!
ttcheng
Postby Footprint » Thu Nov 07, 2019 12:43 pm
PatrickLP,
Thank YOU very much!! Your procedure worked like a charm!! This will save me a ton of time since I review contracts all day as part of my job. Thanks for taking the time to explain. :D
Footprint
Postby ck937 » Sun Nov 10, 2019 5:13 pm
Hey PatrickLP - I can confirm that this works. Thank you kindly.
I was also trying some different form fields...and nothing worked. I wonder if the order of the form fields is key? Or perhaps the URL address is key? I had a different URL.
ck937
Postby ninjaccountant » Thu Mar 12, 2020 4:01 pm
Thank you PatrickLP!
Signing into Docusign was such an annoyance in my day. Especially when Im using multiple times in a day.
Works perfectly
ninjaccountant
