Paytrust?
Paytrust?
Postby typhoon007 » Mon Aug 25, 2008 8:50 pm
Can you guys check out the site www.paytrust.com? It uses a two step login, first page with the username, and the second page with the password. Can lastpass handle this?
Thanks!
Other than this, looks awesome so far.
typhoon007
Re: Paytrust?
Postby Gerry » Mon Sep 01, 2008 5:23 pm
Apparently it can handle sites which do this, have you attempted it yourself?
Gerry
Re: Paytrust?
Postby h0pc » Mon Sep 01, 2008 11:53 pm
On these 2 page login sites - you have to keep going and lastpass will recognize when you are actually through the multi-steps.
The one issue I found was on a multi-page login that added an intermediate step on a random basis (maybe not random, but you get the idea). In that situation, lastpass can get confused.
h0pc
Re: Paytrust?
Postby bob » Fri Sep 05, 2008 2:12 pm
If you are having trouble with a multi-step login, there is a good chance it is because the data was imported from the ff/ie pw mgr (or some other password manager) and there was not enough information for LastPass to know that it is a multi-step login.
I would suggest in that case to delete your site in LastPass and use LastPass to add the site (i.e., go to the site and login as usual and let LastPass capture it).
That will give you the best chance of it working. If it still doesn't work, let us know and we will have to look at it.
Thanks
Bob
bob
Re: Paytrust?
Postby bryanwachs » Tue Apr 07, 2009 1:26 pm
I cannot get in not matter what I do either.
Any fixes, suggestions yet?
Thanks
bryanwachs
Users browsing this forum: Norsedakotan and 9 guests
