SAS
SAS
Postby laurens648 » Tue Mar 13, 2018 9:50 am
laurens648
Re: SAS
Postby Bimme70 » Wed Aug 22, 2018 1:34 am
Similar issue with sas.se
I get my username in both username and password field after using the add all fields feature. The password field is listed as a username field when you edit the lastpass entry.
Bimme70
Re: SAS
Postby Andreass » Thu Jul 04, 2019 9:28 am
Sorry for reviving an old thread but does anyone know how to work with this? I guess they deliberately do this to deter password managers.
Code: Select All Code
<input aria-invalid="false" [b]id="Loginemail" name="LastName"[/b] type="text" maxlength="60" numbers-only="" allow="removespace" move-cursor-to-end="exceptHyphen" autocomplete="off" aria-required="true">
<input aria-label="Lösenord *" aria-required="true" aria-invalid="true" [b]id="Loginpassword" name="LastName"[/b] type="password" maxlength="50" numbers-only="" allow="removespace" move-cursor-to-end="exceptHyphen" autocomplete="off">
Andreass
Re: SAS
Postby onri » Mon Aug 05, 2019 8:29 am
I'm also looking for a solution for these websites, annoying to have to type the masterpassword to copy the sas password on each login.
onri
Re: SAS
Postby Andreass » Mon Mar 02, 2020 10:28 am
It works fine now!
Andreass
Users browsing this forum: MSN [Bot] and 12 guests
