Mobile Campus login problems
Postby spreng » Wed Dec 02, 2009 2:18 pm
Is there a way to get LastPass to properly log in to Mobile Campus (http://www.mobilecampus.com/)? LP fills in the required cellphone number, but when I click "Login" LP does not recognize the Password entry box.
spreng
Re: Mobile Campus login problems
Postby JoeSiegrist » Thu Dec 03, 2009 3:33 am
spreng Wrote:Is there a way to get LastPass to properly log in to Mobile Campus (http://www.mobilecampus.com/)? LP fills in the required cellphone number, but when I click "Login" LP does not recognize the Password entry box.
Have you tried step 5: https://lastpass.com/help.php?topic=log ... mwebsite=1
Postby spreng » Thu Dec 03, 2009 11:53 am
Yes, I tried that, and I can get it to work, sort of. The mobilecampus site requires a multi-step login process where you enter your cellphone number, then click a Login button and then enter the password in a drop-down box. I don't know if LastPass can even hanldle automating that kind of process.
Thanks for your help,
Patrick
spreng
Postby JoeSiegrist » Thu Dec 03, 2009 12:11 pm
spreng Wrote:Yes, I tried that, and I can get it to work, sort of. The mobilecampus site requires a multi-step login process where you enter your cellphone number, then click a Login button and then enter the password in a drop-down box. I don't know if LastPass can even hanldle automating that kind of process.
You can use Save All Entered Data for each page...
Postby spreng » Thu Dec 03, 2009 12:55 pm
That works, but it still leaves it a three-step manual process -- LP fills in the cellphone number, I click the login button, then I select the appropriate AutoFill option for the password and click on the second login button. I can live with that.
Thanks,
Patrick
spreng
