http://www.examenonline-klinik.de/
Postby maesju » Mon Sep 08, 2008 4:05 am
Hello,
the site http://www.examenonline-klinik.de/ is a german e-learning site for medical students. Whenever I try to log in via the lastpass add-on (I am using it with firefox 3) it inserts the right password but instead of the username I get some kind of encrypted text string like "Aedh4h4rfjfrfj45po5". When I use Opera and log in via lastpass.com everyhting works just fine. The IE plugin also doesn't provide the username but unly the encrypted version of it.
Thanks for the great tool anyway.
Matthias
maesju
Re: http://www.examenonline-klinik.de/
Postby bob » Tue Sep 09, 2008 8:46 am
Hi,
I am having trouble reproducing this problem (worked perfectly for me).
Could you delete your existing account in lastpass and re-login into the site and re-save? I believe it should work.
Let us know if it is still giving you problems. If you can recreate the problem, I am sure we can fix it.
Thanks
Bob
bob
Users browsing this forum: No registered users and 10 guests
