Android browser
Android browser
Postby EliezerB » Thu Feb 16, 2012 3:29 pm
On the LastPass description of the Android app at:
https://lastpass.com/features_premium.php
it says:
No matter where you are, you can view, add, edit, and delete your sites and secure notes from your Google Android device, a built in browser allows you to login to your sites.
Does that mean LastPass installs its own browser - or does it mean it uses the Android's standard built-in browser?
Thanks,
Eliezer
EliezerB
Re: Android browser
Postby mynetdude » Fri Feb 17, 2012 2:56 am
EliezerB Wrote:On the LastPass description of the Android app at:
it says:
Thanks,
Eliezer
Yes it installs its OWN browser so that it will autofill forms, you can also get the Dolphin browser and the lastpass plugin and it will do that and much better.
mynetdude
Users browsing this forum: No registered users and 33 guests
