Fedora 15 / Chrome last pass crash
Postby coachz » Wed May 25, 2011 11:05 am
I am unable to use the last pass extension in Chrome 11.0.696.71 in Fedora 15. Since all my passwords are in this plugin and Chrome is the browser I use I'm kindof desperate for help. The crash occurs during the installation of the last pass plugin.
Thanks for any ideas.
coachz
Re: Fedora 15 / Chrome last pass crash
Postby Israel » Wed May 25, 2011 2:30 pm
Disable SELinux in Fedora and it should work - there's a bug we've reported to them.
Israel
Site Admin
Postby Mandrake » Sun May 29, 2011 2:43 pm
Execute the commands in terminal:
cd ~/.config
sudo chcon -Rv unconfined_u:object_r:config_home_t:s0 google-chrome
Here it worked 100% with LastPass and XMarks
Font: http://fedoradicas.x4ids.com.br/2011/05 ... comment-39
Cya.
Mandrake
Postby jpalko » Mon Jun 06, 2011 3:42 am
A quick command to run as your user that may fix issues with more than just chrome:
Code: Select All Code
$ restorecon -R -v -F ~
Seems to have fixed one of my wine problems as well on one host. :)
Many people have said that chrome has just started working for them and it has been like that for me as well on one of my Fedora hosts but others have needed this command.
jpalko
Postby realmrealm » Wed Jun 15, 2011 12:06 am
@jpalko
You were right on with your advice. Running the command you mentioned solved the issue perfectly. From what I can tell it forced a rescan of everything in my user directory, and SELinux was happy again. (fedora 15 / 64bit / chrome dev version)
@Israel
"disable SELinux" is not an answer, not a good one at least. Sorry, I know I'm a newbie, and you have over 600 and some posts, but disabling a key security feature for an entire system to make an extension of a browser work is a bit silly. That's like taking off your bullet proof vest because your cellphone holster doesn't fit right when you wear it.
realmrealm
Postby jphustman » Fri Aug 05, 2011 5:47 am
Yes, Mandrake's solution solves this problem. I didn't get any warning from SELinux about anything though. This is on a fresh install of 64-bit Fedora 15.
jphustman
Postby coachz » Fri Aug 05, 2011 7:02 am
disabling selinux on F15 fixed me on Chrome 13.0.782.107
coachz
Postby jphustman » Fri Aug 05, 2011 3:54 pm
I wouldn't completely disable SELinux, it is there for a reason. And like realmrealm said, disabling a system security feature for a simple thing as last pass is not smart. Take the time to learn about SELinux and why it is there. http://selinuxproject.org/page/Main_Page
jphustman
Postby coachz » Fri Aug 05, 2011 5:49 pm
i always disable selinux. drives me nuts
coachz
Users browsing this forum: No registered users and 64 guests
