Custom Form Fields Not Retained
Postby abuladeen » Mon Jun 29, 2020 4:45 pm
I'm using LastPass with the Chrome browser with an Asus Flip A302C Chromebook.
Using the Edit Form Fields button in the Edit password dialog box, I defined custom form fields to log in to the federal payments website, EFTPS at https://www.eftps.gov/eftps/login/loginInitial. After creating and populating the fields, I saved the account information in LastPass, then tested it to make sure the EFTPS login fields were filled correctly.
However, returning to the website a day or two later, I found that some or all of the custom form fields had disappeared. I repeated this series of events a number of times because I couldn't believe this loss of data was really happening.
I'm seeing a couple forum posts from about four years ago reporting this problem. Other than the suggestion that Save All Entered Data is a more reliable way to accomplish the same thing, I'm not sure I see anything that looks like a solution. Even if Save All Entered Data works, manually creating the custom fields ought to work too.
Any help with this?
abuladeen
Users browsing this forum: tvdv1900 and 40 guests
