Login With PIN Not Working On Android Phone
Postby scottfinnell513 » Tue May 26, 2020 11:04 pm
I don't understand this, I used to be able to login to Lastpass on Android using a PIN. For some unknown reason, it doesn't work anymore. I have it set to use PIN, but not working. I have a very long complex master password, and the only way I can get into Lastpass is to keep a text in notes of the password and copy and paste. It's a pain in the neck! Please fix this issue, or let me know what is wrong. I have settings exactly the way they were when it was working.
scottfinnell513
PIN Doesn't Work Android
Postby scottfinnell513 » Tue May 26, 2020 11:08 pm
The login PIN feature doesn't work on Android, and neither does the feature to use Lastpass on Chrome in Android. I have a very long complex master password, and it's a pain in neck to login. It used to work, so why did it stop working? Any suggestions would be great!
scottfinnell513
Re: Login With PIN Not Working On Android Phone
Postby tnkithcart897 » Fri Jun 26, 2020 4:33 pm
I am having the same issue. It's cumbersome to have to enter my complex password every single time. Have you received a response? Any resolution?
tnkithcart897
Postby bosspublic351 » Sun Jun 28, 2020 4:21 am
Have you guys tried reinstalling the LastPass app and set up PIN again?
bosspublic351
Users browsing this forum: Google [Bot] and 28 guests
