Does LP work with android Edge?
Is LP supposed to work with Android Edge Browser?
Postby SCADAman29325 » Sat May 02, 2020 2:13 pm
I'm using a Note 8 and like the Edge Browser and want to use LP instead of the browser pw storage, but can't figure out how to fill in the user/pw without opening LP and copy/paste.
Help please.
SCADAman29325
Postby SCADAman29325 » Sat May 02, 2020 2:33 pm
Can't figure it out.
SCADAman29325
Re: Does LP work with android Edge?
Postby DarthSkippy » Tue May 05, 2020 3:14 pm
LastPass cannot seem to fill new Edge browser on my Samsung S10.
DarthSkippy
Postby DarthSkippy » Wed May 20, 2020 2:22 pm
Hi,
I contacted support and was eventually able to get Lastpass to Autofill Edge on Android.
I tried their first suggestion but it didn't work:
Please check if autofill is enabled on your Edge on Android, if it is enabled, then uninstall Edge, power cycle your device, install Edge again and test the issue.
The second instruction was successful though.
1. Open LastPass app > Settings > Actions > Clear LastPass Cache
2. Open LastPass app > Settings > Actions > Refresh Vault
3. Logout, log back in and test the issue again.
Hope that helps anyone else having problems.
DarthSkippy
Users browsing this forum: No registered users and 80 guests
