Problem installing LastPass extension on Edge Chromium
Postby gfrangiamone423 » Thu Jan 16, 2020 11:52 am
I've a problem installing lastPass extension on new release of Edge Chromium (official release).
In the installing procedure I get this error: The package is not valid. Detail: "Name of a key "" is invalid. Only ASCII [a-z], [A-Z], [0-9] and "_" are allowed.".
Thanks
Giuseppe
gfrangiamone423
Re: Problem installing LastPass extension on Edge Chromium
Postby etabeta » Fri Jan 17, 2020 10:55 am
Same issue for me: Edge Chromium (79.0.309.65, official build, 64 bit) italian language.
Please note: I think this issue is related to italian (or, in general, to non-english) release, in fact if you change language setting (in Edge) to english the Lastpass plugin install is done successfully (but if you revert Edge to Italian... nope... the plugin is automatically "deleted").
PS.: A possible work-around is to install (in Edge Chromium) Lastpass plugin from the Google Chrome webstore (you must enable "consensti estensioni da altri archivi" in Edge), it works, also in italian. Please note that in the Chrome webstore current Lastpass release is 4.40.2 (15-January-2020) and in Microsoft Edge Addons is 4.40.1.2 (9-January-2020)
Best regards.
Luca
(from Turin, Italy)
etabeta
Postby maurifoitaly » Wed Jan 22, 2020 12:41 pm
Same here ! nothing is changed in 5 days ?
maurifoitaly
Postby fesdena79 » Sun Jan 26, 2020 6:07 am
Same problem here
fesdena79
Postby giuswhite » Thu Jan 30, 2020 5:09 am
Same problem. Edge with italian language :(
giuswhite
Edge Chromium extension error
Postby Oldfeeling » Mon Feb 03, 2020 11:58 am
Hi,
I'm trying to instal Edge Chromium extension from the store but I got the following error at the end of the download:
Edge Chromium version: 79.0.309.71 (64 bit)
Anyone facing the same issue?
TY
Oldfeeling
Postby jonat » Mon Feb 03, 2020 3:22 pm
Any particular reason you don't want to install from the Microsoft Store? I did and it works fine.
jonat
Postby Sauramud » Tue Feb 04, 2020 7:52 am
I've got the same problem here with a fresh new Edge Chromium installation. "Name of a key "" is invalid..."
Does anyone have a workaround?
Sauramud
Postby cdariz » Wed Feb 05, 2020 3:39 am
Same problem even from Microsoft Store. Any solutions?
cdariz
Postby leevy27867 » Thu Feb 06, 2020 7:23 am
Hi guys,
Go to the menu at the top right corner and chose Extensions. In the Extensions Window, at the very left bottom, enable Allow extensions from other stores.
Then go to the Google Webstore and search for lastpass and download/install the extension. It works for my pretty good.
leevy27867
Users browsing this forum: No registered users and 59 guests
