Empty error when adding new password
Postby fasaxc » Sun Oct 20, 2019 8:39 am
When I log into a site and then click on the lastpass popup to save the password, I either get an empty error popup and the password is not saved or I get an "Invalid response" error popup. I've tried clearing the local cache and removing/reinstalling the Chrome extension to no avail.
This happened after storing lots of passwords (doing my initial import by manually going to each site and logging in).
fasaxc
Re: Empty error when adding new password
Postby batman123 » Thu Oct 24, 2019 7:23 pm
I'm having the same problem
batman123
Postby brandiricole477 » Tue Nov 12, 2019 7:51 pm
I'm having the same error when it tries to save new passwords. It's getting frustrating because I rely on it working.
brandiricole477
Postby blargh538 » Tue Mar 31, 2020 9:43 am
I have the same problem as well. I never get the "invalid response" but I get two empty error boxes when I try to save a login. I cleared the cache and even uninstalled and reinstalled the plugin. It worked once then broke again. Are there any logs anywhere that might be able to help me troubleshoot this problem? My Firefox extension has been really buggy for a while now. This and other problems I've experienced recently after prior years of issue-free operation have caused me not to recommend Lastpass to people anymore. I work in IT so if it's frustrating to me then I'll bet a normal computer user will just give up and go right back to writing their passwords down on sticky notes.
blargh538
Postby jamesjay » Tue Jul 14, 2020 3:37 pm
I am having the same problem, whenever I am trying to save a new password, it is happening both with the popup and when I try to enter the site as a new password directly on LastPass... I always get 'Error Invalid Response'. This is irritating because I want to save these new passwords on some sites that are important to me. Help!
jamesjay
Postby JWorsley » Sat Aug 01, 2020 2:17 pm
Is there an answer for this error message? I'm using generating a secure password from LastPass but it won't save it so I can't use the password. Comes up with Error Invalid Response. Thanks for your help.
JWorsley
Users browsing this forum: No registered users and 35 guests
