Internet Explorer - Extension Enabled and Not Working
Postby brettingsworth » Fri Sep 13, 2019 12:13 pm
Lastpass is not working for IE 11. Since the update, the login extension has disappeared and I cannot login. I've deleted from my system and then reinstalled and still no Bueno. Anyone else experiencing this?
brettingsworth
Re: Internet Explorer - Extension Enabled and Not Working
Postby rnasch636 » Fri Sep 13, 2019 10:11 pm
Yes I'm experiencing the same thing. I've tried uninstall reinstall etc... working with Chrome and Edge no problem but not with IE 11
rnasch636
Postby jpham406 » Mon Sep 16, 2019 2:01 pm
Well this is unfortunate. same here. a reinstall gives me an error code 1603 anyone have that problem?
jpham406
Postby bf123456789 » Tue Sep 17, 2019 11:24 am
Yep, Same issue. I also get error code 1603 when I attempt to re-install.
bf123456789
Postby rheyer » Tue Sep 17, 2019 2:35 pm
Same here All of a sudden stopped working on all browsers. After re-installing Chrome and Edge are working but getting same 1603 error for IE. This is really causing me pain as I use IE for most sites.
rheyer
Postby rheyer » Tue Sep 17, 2019 3:00 pm
Also I tried calling and that just tells you to go to support page and then hangs up. I tried 3 times to submit a support request but after hitting the send button nothing is happening.
rheyer
installation failed error code 1603
Postby angela900 » Tue Sep 17, 2019 3:26 pm
Lastpass keeps getting messed up... this is a new machine completely wiped 3 months ago...I keep having to reinstall lastpass chrome plugin.
I have lost the ability now to access it through chrome. I can't reinstall the plugin. what is going on?
this is what I receive "installation failed error code 1603"
I read one post here that said to enable powershell 2.0 but that it can cause security issues and researching it was deprecated.
So what other solution is there to get this to work...
thanks,
Angela
angela900
Postby jpham406 » Thu Nov 14, 2019 1:10 pm
last pass version 4.34.0 or 4.35.0 still has the same error 1603 for Internet explorer.. do they even read these so called forums? help from last pass is ridiculously dumb.
jpham406
Postby jpenny84 » Thu Nov 14, 2019 1:58 pm
jpham406 Wrote:last pass version 4.34.0 or 4.35.0 still has the same error 1603 for Internet explorer.. do they even read these so called forums? help from last pass is ridiculously dumb.
There's a sticky topic that clearly explains this forum's purpose, and your other support options:
viewtopic.php?f=12&t=342845
jpenny84
Users browsing this forum: executive8, Google Feedfetcher and 83 guests
