Blank Password Fills
Postby mci01222 » Wed Aug 14, 2019 1:43 pm
I save a password into my vault for a site, but when I try logging in to that specific site it says incorrect password.
I go to my vault and look at the password and it shows ●●●●●●●●● (which is obviously hiding the password) when i select reveal password it still shows ●●●●●●●●●, for some reason lastpass is no longer saving my passwords.
mci01222
Re: Blank Password Fills
Postby jpenny84 » Wed Aug 14, 2019 3:49 pm
The site may be replacing the password input in the field with actual unicode dots, instead of simply masking it by using a password field type. If you have no other way to recall the password for that site, you may need to perform a password reset. Just make sure to generate and save a new password for the entry beforehand, and ignore any password update prompts from the extension when you do the password reset.
The last I read, LastPass is trying to find a workaround for sites doing this.
jpenny84
Users browsing this forum: GregL and 35 guests
